1 - 4 of 4 Posts
So I have finally narrowed it down to 3 frames, the 2008 Turner 5spot, RFX or the Chumba XCL. I cannot find a single bad thing written about any of them. I realize you guys are going to be in favor of Turner, so help me narrow it down to two frames (The Chumba and one of the Turners)
I just need to figure out which one is the best fit. I really don’t care about looks that much, I like they way these 3 frames each look in their own way. It more about performance & durability.
Turner 5 Spot
5.5 inches of travel, and will work perfectly with the parts from my existing bike. I can also re-use my 4 month of DHX 5 Coil on this frame. 5.5 inches of travel is probably perfect for the way I ride and where I ride
Turner RFX
Beefier than the Spot, but still pretty light. It would allow me a growing room if I decide to get more aggressive with my riding. I will need to get a new fork or run my existing 145mm Nixon with a spacer to get the geo where it should be until I can afford a new fork.
Chumba XCL
Beefier than the Spot, but only 5” of travel. But it is also slacker with a 68 HA. Even though it has less rear travel I would put this right in between the Spot & RXF in regards to the amount of abuse it can handle. It would probably be better descending than the Spot.
First thing I need to do is really figure out how much travel I need. I don’t see myself ever going really big on any stunts. The biggest drop I ever see myself doing is 4 to 5 feet with a nice transition. I hit a 42” drop back in November and that is the largest I have ever done. But I do love flying down technical DH’s and want to get better at rollers. With that in mind the RFX may be the best choice. Another though is that I could run a spacer on my fork to slacken out the HA on the Spot. It would still climb well and would be a little better on the DH’s. Keep in mind that I live in New England and ride technical single track (rocky, rooty) and nothing is flat. You are doing a technical climb or a technical decent. I don’t really care about how fast I make the climb, just that the bike will be able to get up the technical stuff. But I do care about how it will handle going down. I love to go fast on the DH and would prefer to not have to worry too much about my line.
Where in New England do you ride? Unless you run back to back laps at Vietnam all day, I would say the Spot is going to be a better ride for around here. Is this going to be your only bike or more of a dedicated "gravity" fun bike? If the latter is the case, then perhaps a light build on an RFX could work very well.
Discussion Starter · #3 ·
I live in Western Ma and like to ride Barchleor Street and the Metocomet trail in Ma. In Ct I frequent Case Mt, W. Hartford Rez, Nassahegan and occasionally Nepuag. This will be my only bike.
The 5.5 spot seems like a better choice based on your description details.
parts will swap over
the spacer idea sounds good for HA adjustment
the spot can handle alot of abuse. I was never afraid to jump mine on most gaps up to 20 feet or so. given you dont land like a tank it will hold up to your growing desires on the trail.
1 - 4 of 4 Posts
