I've seen a few other reviewers/complainers about problems with this system.
Mine loosened up/stripped out during an endurance race yesterday at a very inopportune time (I'm a relatively new racer and was having one of my best rides thus far). This was very disappointing- sort of kicking myself for just not buying xtr (which is usually my solution for when things break). The same problem also happened earlier in fall (which I blamed on improper installation and just replaced bolt, very carefully with proper tq etc. etc.)
The temperature changes recently are likely at least partially to blame (but that's not acceptable either). I did check it/tighten it prior to the start.
I spoke to some friends and we decided to go ahead with trying to source a steel (or maybe Ti) bolt to replace the aluminum one.
thoughts on this? what have others done?
edit- I should mention I also emailed them for help (but I wont' just be replacing it again, this is 2nd time)
I got concerned about the fsa carbon pro compact crankset I have sitting in a box waiting to go on my gravel race bike too (it uses similar system)... opened that up and the bolt in there is steel and has loctite on it from the factory. I'm assuming I will be ok there...
