1 - 6 of 6 Posts
A 2007 XAM 2 has served me exceeding well for 2 years. I have searched the web, have asked reps many times for tech info. Tonite I have located a site for fans of the 2007 XAM's.This will make it easy to order replacement parts and provide a better understanding of how it all goes together. Enjoy:thumbsup:
http://www.maruishi-cycle.com/jamis/07tech/SUS/XAM/index.html
Discussion Starter · #3 ·
Bearings
Think about what you are getting. I decided to go with Enduro, the only ones you can't get fromthem are the 2 pair inthe link the 689's. I have all mine in from enduro, waiting on the others. Also purchased the headset bearing. Good lick
Discussion Starter · #5 ·
Replacement Bearing
Check out this link for bearing replacement. http://www.enduroforkseals.com/
Now that we have uncovered a few 07 XAM owners, how about hearing about you setups and experience with the bike. The site is so full of negative energy. I have broken and worn out lots of stuff. I just fix it and go riding. Positive vibe will get you through.
Discussion Starter · #6 ·
Up Dated XAM Spec's, Work Needs to be done.
Boys, Decided to check my bearings, it's real wet here, The bottom bracket and drop out pivot bearings were real bad. I just found out my nice Enduro 698's aren't correct, the drop out takes the new 698-10 bearing used on all the current bikes. I'm attaching a parts list that I have been able to put together from the net. Still trying to fill in the blanks and will update. Cheers
2007 DAKAR XAM Derrailer Hanger 12-3580 S/A 06 Diablo & XLT or 12-0777 Revised
No# Part Number Description Spec Detail Quantity
1 XAM Shock Mounting Bolts  Washer 14 x 6.5 x T1.2 STAINLESS 2
2 UNIQUE to 2007 XAM  Washer 13 x 8.5x T1.5 SPCC 2
3 "  Screw set (Link Pivot) M6 x 1.0 x 8 x L34 2
11 "  Screw M6 x 1.0 x 8 x L42 2
5 XAM Seat Tube Pivot Washer 10 x 5.2 x T1.0 STAINLESS 6 6 UNIQUE to 2007 XAM Ball Bearing 15 x 9 x T5 689 2RS 4 7 " Pivot Spacer 11 x 9 x L27 Alloy 6061-T6 1 8 "  Pivot Axle M5 x 0.8 x L49 STAINLESS 1
9 "  Screw M5 x 0.8 x L15 2
10 "  Bushing 9 x 5 x 5L S45C 2
4 "  Screw M5 x 0.8 x L20 2
12 12-2003 Bottom Bracket Pivot Assembly
  Alloy Cap Nuts 2 1x 17 x 2.5 x L25 Alloy 6061-T6
29.5 x 17 x 3 xL25 [ new style] 2
13 Same as 09 Parker, XC Ball Bearing 30 x 17 x T7 6903 2RS 2 14 "  Bushing 24.0 x 17.0 x T4.5 STAINLESS 2
15 "  Screw M12 x 1.7 x L46 STAINLESS 1
16 12-2602  Drop Out Pivot Assembly
Ball Bearing 19 x 8 x T6 x 10[inner sleeve] 6982RS-10 2
17 Same As 09 XAM, XCT,XCR alloy, BAM, PARKER Screw M6 x 1.0 x 8 x L15 2set
20 2007 XAM UNIQUE  Bell Crank Plate Alloy 6061-T6 1set
1 - 6 of 6 Posts
