Here is a typical frame size chart:
Adult Bicycle Frame Sizing Chart
Many manufacturers offer bicyles in several frame sizes for a personalized fit. Straddling the bicycle standing flat footed on floor, you should have a minimum of 1-3" clearance between your inseam and the top tube of the bicycle frame. Due to varying body types, the chart below should be used as a guideline only for frame sizing.
Height 66" - 70" 70" - 73" 72" and up
Frame Size 16" - 17.5" 18" - 19.5" 20" - 22"
Small Medium Large
The typical frame size is measure by the seat tube length. This chart is not completely accurate nor set in stone a but a guideline. Im 5'11" or 71" and according to the chart should be in the 18" - 19.5" range. I have an Iron Horse and chose the 17.5" size as I felt the next size up... 19.5" was too big. Fit is extremely important but if you cant test ride it you can get close. Another important factor is top tube length. Some will argue it is more important and to some extent I agree but you can adjust it somewhat with stems, handle bars, seat posts and saddle positioning so I believe standover clearance is more important and most sites list those specs. Use your inseam to determine your standover height needed. The Iron Horses are great values but it is a risk you take buy not being able to get you hands on it first. Luckily I did. As much as I like Iron Horse, I'd call an LBS even if they are 2 hours away to see what they have to offer. With today's economy and considering the distance you'd have to travel they might be able to offer you a deal. All they can do is say no and you wont know without trying.
