1 - 1 of 1 Posts
after a bit of searching seems the likely culprit is a lower rear shock bushing. it has the original specialized shock. the symptom is, when i lift on the saddle i have a very slight tick/click/play.
i overtightened the original lower bolt and the bolt head cracked. i've since replaced it with a high hardness steel bolt and torqued to 120 in-lbs.
is there a source for replacement bushings for this vintage shock?
1 - 1 of 1 Posts
