mb300 said:
I'm running 48psi on the not so nasty trails and 52psi on the big stuff. Plushness definately increases at lower pressures, but so does the risk of going over the bars
I think one of the issues is that plushness is relative - my other forks are a talas32 and a Pike, both of those forks are mega plush compared to the talas36.
Gotcha.....
MB, focus on getting the correct sag with air pressure and just leave it regardless of the terrain you're riding. Then, dial in the high/low speed compression adjustments as necessary to control bottom out on big hits (high speed) and brake dive /unwanted bob (low speed). FYI, the big knob is the high speed. Small is low. I kept forgetting that.
On most of our xc trails, I'm running just 1-2 clicks on both and I'm using all of my travel on those rides. On some FR trails, I've taken this fork on, I've upped the high speed as much as 8-10 clicks and it did great in regard to bottom out and that was off 7+ foot drops (true size) where I sailed 10-15 feet down the hill. No issues whatsoever.
A good reference is that if you're not bottoming your fork out 1-2x per ride (not violently, mind you), it's probably too firm or the compression is set too high.
Cheers,
EBX
