- Stronger, stiffer 6061-T6 alloy frame, Freeride HT Dirt Jumping/Street/MTB design, double butted ORE DT and TT, forged/releived "Cobra" HT and ISCG BB, 6mm offset rear triangle and forged horizontal drop-outs with integrated chain tensioner and replaceable der hanger
- Lighter Marzocchi Dirt Jam Pro SL, 110mm "Disc" model, SSV dampening, 1-piece magnesium lower, Cr-Mo steerer, black alloy 32mm stanchions, cold forged alloy crown, coil spring w/ air assist
- More powerful Hayes Sole, hydraulic disc brakes with BFL levers and 160mm V-cut rotors
- Truvativ Hussefelt, 6066 with howitzer interface and Truvativ XR box guide chain guide
- SUN SingleTrack Disc, 26", 36 hole, eyelets
- FRAME 06 P-frame, 6061-T6 alloy, Freeride HT Dirt Jumping/ Street/MTB design, double butted ORE DT and TT, forged/releived "Cobra" HT and ISCG BB, 6mm offset rear triangle and forged horizontal drop-outs with integrated chain tensioner and replaceable der hanger
- REAR SHOCK None
- FORK Marzocchi Dirt Jam Pro SL, 110mm "Disc" model, SSV dampening, 1-piece magnesium lower, Cr-Mo steerer, black alloy 32mm stanchions, cold forged alloy crown, coil spring w/ air assist
- HEADSET Tank FS, 1 1/8" threadless
- STEM Truvativ Hussefelt, forged stem, 7 degree x 40mm, 31.8mm bar clamp
- HANDLEBARS Specialized alloy riser, OS 31.8mm , 45mm rise, 8 degree upsweep, 6 degree backsweep, 640mm width
- GRIPS Specialized Enduro, Kraton dual compound
- FRONT BRAKE Hayes Sole, hydraulic disc, 160mm V-cut rotor
- REAR BRAKE Hayes Sole, hydraulic disc, 160mm V-cut rotor
- BRAKE LEVERS Hayes Sole with BFL lever
- FRONT DERAILLEUR None
- REAR DERAILLEUR SRAM SX-5, short cage
- SHIFT LEVERS SRAM SX-4 Triggers, 8-speed
- CASSETTE SRAM PG-830, 11-28t
- CHAIN Shimano IG-31
- CRANKSET Truvativ Hussefelt, 6066 with howitzer interface and Truvativ XR box guide chain guide
- CHAINRINGS 34T heat treated Cr-Mo
- BOTTOM BRACKET Truvativ Howitzer Team, 57mm chainline, external alloy cups, sealed cartridge bearing
- PEDALS Specialized alloy platform, molded pins, 9/16" Cr-Mo axle
- RIMS SUN SingleTrack Disc, 26", 36 hole, eyelets
- FRONT HUB Joy Tech disc, 36 hole, nutted axle
- REAR HUB Joy Tech disc, cassette 36 hole, nutted axle
- SPOKES 2.0mm (14g) stainless steel, brass nipples
- FRONT TIRE Specialized Rhythm 26x2.3", 60TPI, dual compound with wire bead
- REAR TIRE Specialized Rhythm 26x2.3", 60TPI, dual compound with wire bead
- TUBES Specialized schraeder valve
- SADDLE Specialized Fuse w/ 8mm rails
- SEAT POST Alloy micro-adjust, 30.9x300/350mm, for 8mm rails
- SEAT BINDER Alloy collar with Q/R
