I have a new 2006 Titus Racer X med frame with the Fox F100RLT fork and Fox Float RP3 on back. I set the rear shock air pressure to that recommended by Fox at about 1/4 travel length sag. However, I found the ride to be a little too squishy for my taste, but then I had come from a 2000 Rocky Mountain Instinct with Marz front coil shock and early Fox Float air shock on the rear. I weigh 160lbs and ride pretty aggressive style X country, with plenty of eastern Canada style single-track.
Is the Fox pressure recommendations the most efficient, or should I pump it up a little more in the rear, and the front? Currently, I have 60lbs in the rear and 70lbs in the front. Should they be the same psi?
What ratio to rider weight and psi do you find effective?
Thanks…
Thanks…
