Cloxxki said:
All Surly's seem to have 27.2 seatposts and 30.0 Clamps. With the 30.0, clamp, the monocog would have slightly thicker walls, at least the seat tube. Makes sense.
But really, 26.8 is the correct size?
Yes. Both steel and aluminum frames use 26.8 posts. I called SBS/Redline and asked them when inquiring about 2006 frames last month. I have both a steel and an aluminum 2005 Monocog, and they are the same, 26.8 post sizes.
Steel: The steel Monocog frame uses a seat clamp that is bigger than 28.6 and a 31.8 is too loose. I tried different sizes and brands of clamps on mine. To the best of my ability measuring, the stock seat clamp that came on my steel Monocog is 29mm. The seat tube itself measures 28.6. I know Hope makes a 28.6 QR clamp, with a 28.6 bolt-on coming soon according to this:
http://www.hopetech.com/products/products_index.htm
On One makes another clamp that is 28.6/29mm.
Aluminum: The aluminum Flight Monocog uses a 31.8 post clamp according to SBS. I built up my aluminum Flight, didn't come with a clamp, and a 31.8 Salsa was very tight. Was told it was from thick frame paint. I have tried a few 31.8 clamps on it that I had laying around, and I have a 31.8 DKG on it now, which went on a bit easier and fits snug, but seems right. So I'd say that is correct on a 31.8 clamp on an aluminum Flight Monocog, just be careful chipping the excessivly thick (2005) frame paint. 2006 Flight Monocogs have an anno-like matte red finish on them, and no problem there. We measured the 2006 Flight seat clamp size as 31.8 on a stock bike in the store where I ordered the 2005 frame from.
Cheers,
Dave
