1 - 2 of 2 Posts
As the title says, I have a 2005 S-Works FSR 120 with the Fox R and seat stay mounted brain. While servicing my bushings the banjo fitting for the brain hose to the shock body came a bit loose and the pressure inside was vented to atmosphere. Been searching around, can't find any info on how the shock is made and what was released.
Am I looking at compressed air from my shock pump, or did I let a nitrogen charge out of the can?
Did you check the shock pressure with your pump to see if that's what came out??? If your air charge is still in there, then you know something else came out.
1 - 2 of 2 Posts
