1 - 4 of 4 Posts
Rebuilding my 5th element is too expensive. I want to mount a Fox RP23 that I have. Anyone have mounting hardware info or even other shock choices if the Fox can't be mounted. I have seen a 2005 Zen with a Fox so I think it should be possible. Thanks!
5th air or coil ? Coil 5th uses the same hardware as a Fox. Measure your current shock (eye to eye & stroke) and hardware (reducers) and go from there.
Discussion Starter · #3 ·
IT was the standard 5th element air but I have a fox rp23. So do I just ask for the hardware for the 5th element coil shock from Garageworks and it will fit my Fox?
1 - 4 of 4 Posts
