I have been through the archives but can’t quite come to find a solution to my problem.
The Deets…
Trail Riding w/ drops to 5 feet
I weigh 155lbs
The FR SL is bottoming out on 3 foot drops. In fact, I use up almost all the travel just putting all my body weight over the fork and bouncing up and down. The fork is new with a few rides on it. I have been experimenting with different positive and negative pressures with little effect.
I decided to take it apart and check the oil levels, thinking that they might be low and causing the fork to bottom out. I removed all the oil in the ECC leg and looks to have about 140CCs of oil.
Will an increase in the oil level reduce the bottoming? And if so, how much of an increase should I start with given my weight/riding style?
The Deets…
I weigh 155lbs
