I have an 2004, small 5 Spot with a PUSH'ed RP23 and PUSH rockers.
The '04 Spot has the front der. cable stop is at the back of the seat tube and does rub the tire (2.3 and larger) when you bottom out. So, you are limited to the size of tire you can run.
Another problem is that you will have to run the front der. higher because the bottom of the cage will hit the chainstay if you bottom out. When you raise your front der. this can affect your shifting quality. What I did was cut off a section from the bottom of the cage and re-weld it essentially making a short cage front der.
This helped to improve the shifting.
I should also note that I am only running 2 rings in the front (granny and middle).
ANOTHER issue, with my small Spot, is that there is not enough clearance between the Push rockers for my Salsa QR seatpost clamp when the bike gets close to the end of its travel.
I had to go back to the standard bolt clamp that came with the frame.
Adding the rockers does increase the BB height and I believe slackens the head angle.
Based on all of that I do not know if those issues will be evident on a Burner.
