Well like you said you're just riding for fitness/recreation, so the motobecane should be just fine. If you end up getting hooked and become more aggressive with your riding you'll definitely need a good full suspension bike. That DB is "full suspension" but it's more like a spring on the front and a spring on the back. The ride will be rough at best. As you get into some rougher terrain you want something a bit more plush that will absorb the hits.VOLVO S70 said:I think that I'm a size 19. Ii just wasn't sure if the db was better or not. From the reviews it seems like the motobecane is a better bike. And from the reviews of bikes direct seems like folks have nothing but good things to say.
You don't want the top tube so long as to make the handle bars hard to reach(you want a slight bend to the elbows at seated position) To short and you will feel cramped. Best bet is to sit on al the bikes you can and get that "feel" that makes you feel that yo ucan throw that bike around on the trail.VOLVO S70 said:What do I need to look for with the top tube length?
That Hardtail is preferable to the pogo stick DB you're looking at. Riding that thing will do nothing but discourage you. BikesDirect sells nicely specced bikes at a decent price. You just need to do some minor assembly upon receipt. The first 29er I had was a Fantom Cross Pro HT from them and it was specced to a level which I would have had to pay at least a couple hundred extra for at a LBS. Full suspension is a choice that is up to rider preference. I've been MTBing for over 20 years and now find myself on a rigid singlespeed 29er. Good Luck with your choice. As far as frame size, how tall are you?VOLVO S70 said:Sounds good. I think the hardtail should be good for now. But I'm assuming as you get more agressive a full suspension is better?
I beg to differ. Unless they're downhilling exclusively, why would they want a heavier FS bike that is harder to climb with and saps power when you pedal due to the suspension compressing?wickedone31 said:If you end up getting hooked and become more aggressive with your riding you'll definitely need a good full suspension bike.
My bmc trailfox climbs just as good as my HT Focus Black Forest all I need to do is turn on the pro pedal and lock the fork. Not only does it climb good but it goes down good as well and I dont need to slow over the rough stuff it just glides. I am faster on my fs bike than on my ht in the woods any day because of the better control. The new suspension designs are really good and its so much easier on your back. Sure the fs bike is a little heavier and a little slower on flat ground but its so much better every where else I dont care.SeaBass_ said:I beg to differ. Unless they're downhilling exclusively, why would they want a heavier FS bike that is harder to climb with and saps power when you pedal due to the suspension compressing?
Damned few people "need" a full-squish bike. A lot of very serious, very aggressive riders progress to rigid, single-speed bikes - totally the opposite of FS. I think you're both over-stating and over-simplifying the case.wickedone31 said:If you end up getting hooked and become more aggressive with your riding you'll definitely need a good full suspension bike.
