I just bought a used 2003 Epic frame, and the Brain shock can wiggle 1/4" at the vertical blowoff valve. I haven't ridden it yet, but it looks like the vertical part of the shock will knock against the left seatstay.
Is this "play" normal for the brain shock?
I dismantled the rear end to check it out, and the the asymmetrical link there are 3 thin washers. From left-to-right, here are the order of components:
Top shock mount -- washer -- asymmetrical link -- washer -- frame -- washer -- asymmetrical link.
Is this sequence correct? I don't feel like this end of the shock is the culprit.
The bottom end of the shock is attached with a 4mm allen fitting that I can't for the life of me figure out how to undo; the allen wrench can pass all the way through and it looks like it's made out of one piece. If I had to guess, I'd say that this end of the shock is where all of the looseness is based.
So, Epic owners: Is it normal to be able to grab the brain and shake it 1/4" from side to side? Does this create noise on the trails? Does anyone put some form of padded in between the Brain and the left seatstay?
