2003 Specialized Bighit with boxxer 888???
1090 Views 6 Replies 7 Participants Last post by  bug-rex
Hey, So im building up a 2003 specialized bighit and i was wondering if a Boxxer 888 would be compatible with the angles of the frame... ??
1 - 7 of 7 Posts
All the world's puppies will die if you fit a Boxxer 888 to that frame...
Would prolly take a look at some of the fork manufacturer's sites before I would post to much more, if I was you.
Those frames are best suited to forks around 170mm although they work sweet with a 190mm Shiver also as it has a low axle to crown height.
I've never even heard of a Boxxer 888.
I've put a 2008 Marzocchi 888 ATA WC on my 2003 Bighit Expert, but then I also have a 26" rear wheel. It's absolutely unbelievably good. Don't know what it'll be like if you still have the sstandard 24" rear wheel.
Ive seen a ton of the older Big Hits with 888s. You should have no problems.
So are you asking about the boxxer or the 888? I'm confused with your question...
1 - 7 of 7 Posts
