jbf said:
I just inherited a used, 2002 Z1 FR which I will use on a Titus Swithblade with 5.25" rear rockers. The 2002 model has 30mm stantions instead of 32mm like the current model. I have a 30mm Marzocchi air cap and was wondering if I can convert one side to air, like the current MX series.
Anyone know if this would work? Which side ? How ? Help ????? - Thanks
You have to have the air cap for the cartidge forks (like the atom or marathon)... then it's as simple as taking that preload knob off, the e-clip, unscrewing the cap removing the spring, and putting the other on in the same way. The caps from the non-cartridge forks (dj or mxc/r) will not work.
Now, you will have to play with the oil level to get the bottoming/supple travel working for you... that's where the challenge will be.
Let us know how it turns out.
(Disclaimer - I have not done this on those model years... it's is speculation, although I think it will work... someone may know otherwise)
