I just received the trailtech hid and it is Awesome. Light draws 13watts, has a softstart, pulse width mod, the battery is a 14.4V 4000mahr so runs for just over 4 hrs. Initial current draw is less than 0.87A though that increases as the batt voltage drops.
The light is excellent ! Build quality is very good.
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=1332
The battery can be a bit iffy due to the IC / PCB compatibility with the soft start on the trail tech - but there is an easy fix for it: I talked to tech support at batteryspace and they are aware of the problem since there have been a few battery complaints but they did not have a fix but were offering to return for refund..
I've just finished wiring up a bunch of 18650 li-ion batteries nicked from a notebook powerpack using the PCB from battery space. ( which is the same that you get on the 14.4V battery packs sold).
If the HID will not fireup with the PCB in place but will fireup when connected directly to the battery - then you need the "smooth" the current draw from the PCB with a small capacitor. just solder a capacitor of 16V and around 1000microF across the PCB power output (follow the polarity of the PCB and the capacitor) and that solves the problem .
