1 - 7 of 7 Posts
· Registered
I have a 2019 Pike RC and TRP Slate T4 brakes. I'm currently running a 180mm rotor in front which means no adapter. I want to upgrade to a 200/203 rotor (I will buy the appropriate size adapter depending on what rotor I get). I've looked at TRP and Galfer so far and the adapters look significantly different (however the pictures may not represent what you would actually get). Are adapters like this universal?
· Single Track Mind
I am not exactly sure, and I had the same question, so no help there. I do know that when ordering the adapter from Galfer directly, they will ask the make and model of the brake. I just went with a larger rotor up front, Galfer's 203mm floating rotor, so the experience is still fresh. I'm guessing that there isn't a tremendous amount of difference between caliper footprints, but even 1 or 2 mm would make a difference. Sorry I couldn't be more help.
· B A N N E D
Galfer's 20mm adapter looks to be the old 4 bolt type, Shimano used to make adapters like that before they changed to the current 2 bolt design that most other brake manufacturers use.
Generally adapters are universal but I've seen some forum posts where occasionally there's a clearance problem where some 4 piston calipers didn't fit in some adapters properly.
If your caliper fitted on the Galfer 20mm adapter, it would work with a 200mm rotor on your fork, if you wanted to use a 203mm rotor, you might have to shim the caliper on the adapter.
If you wanted guaranteed caliper and adapter compatibility, get a TRP adapter.
· Guest
I always try to get the adapter that matches my brake from the actual company. However I recently got into a pickle with my Maguras and an adapter that was nowhere to be found. I ended up trying the Shimano 180 adapter I had laying around and it worked perfectly. I think it's hit or miss which adapter will work with which brake.
1 - 7 of 7 Posts
