Show me your 2-speeds! What ratios? Which cranks? Does ENO have anything to do with it?
Very nice! I like that a lot...Gambler said:Here's my Matt Chester Indie Rock. Schlumpf 2 spd internal bb planetary gear system. 1.65 multiplier. Thus my 34t turns into a 55t. Currently running a 23t eno which is about right for the riding I do. Just finished the build, thus i'm still getting the bugs out. So far, a very fun bike.
cool, that really gives you 2 bikes in one. you've got the 55t for road duty and the 34t for trail. i forgot all about the schlumpf. wish they did 180mm cranks!Gambler said:Here's my Matt Chester Indie Rock. Schlumpf 2 spd internal bb planetary gear system. 1.65 multiplier. Thus my 34t turns into a 55t. Currently running a 23t eno which is about right for the riding I do. Just finished the build, thus i'm still getting the bugs out. So far, a very fun bike.
yeah, i'm glad they went with a 3 tooth spread instead of 2. better to have a to-the-trail gear and a trail gear. but where do you find 31t chainrings for 31-34 or a 35t for 32-35?? W/ a 29 inch wheel running the 16-19 in the back makes the front kind of tricky.nogearshere said:I don't have pics but i have been running the ENO DOS for over a month.
they just can do no wrong...
What you have to realize is that schlumpf cranks are just standard square tapers - except for no spider on the right crank. A little work with hacksaw&file - voila! I run a speedrive on my roadbike - didn't like the looks of the stock cranks, so I found a removable spider crank in black and all is well. Now the only sad thing about schlumpf is that you can't use them fixedpseudo intellectual said:cool, that really gives you 2 bikes in one. you've got the 55t for road duty and the 34t for trail. i forgot all about the schlumpf. wish they did 180mm cranks!
Those are good ratios, prolly what I'd want to use too. Guess I could go the flip-flop route. Old skool!jeff said:38/16 34/20
The 38/16 is perfect for the spin to the trails.
pseudo intellectual said:Those are good ratios, prolly what I'd want to use too. Guess I could go the flip-flop route. Old skool!
The 5 mile spin-like-an-idiot up the path to the trails has lost its charm...
Hey, do you have that new bike yet?
-T
Kinda old pics, but it's all I have. Square taper XT cranks, 22/32, 18T rear, SRAM Woody derailleur as tensioner:pseudo intellectual said:Show me your 2-speeds! What ratios? Which cranks? Does ENO have anything to do with it?
One speed over the limit too!Nat said:One more:
Edit: Ooooops! I just realized this is the 29er board and not the singlespeed board. Heh heh!
I don't have a pic right now but my inbred has 44*12 (outside) and 32*20 (inside) - I have the two cogs on the back spaced equally on a regular hub - works great!pseudo intellectual said:Show me your 2-speeds! What ratios? Which cranks? Does ENO have anything to do with it?
Yeah, I'm sure the Chester is a step up from my PIG IRON beast of burden. But there's something nice about a bike that only gets better with every new scratch in the paint. If only it had a higher bottom bracket. That's my only complaint. Her very significant body mass index doesn't really bother me. She wears it well. Her sister the cross check went under a car last year and came out a little modified but after some rehab is back in action. So there's something to being overbuilt.jeff said:I hear ya on the SS spin like an idiot routine.It works out well with rim brakes also.No adjustments needed.
No frame yet.Should be here in a month or so.No rush on this end with ski season in full swing.It will be a slow winter build.Have you decided on a new frame?I would be more than happy to lend you the Chester for a while, although I don`t know if you could deal with narrow 26" bars and 175 cranks.Fare warning though,one ride on it and you`ll want to hang up the Chunky Monkey for good.
Jeff
