I'm building a dingle speed (not a typo) mountain bike with a Hammershmidt crank set. I mean building, as in the frame also, so if the answer to the following is "no" I guess I will look at making one:
I think the HS shifter is kind of redundant. It has two speeds, not three. I want to press a lever to change gear, and press that same lever again to change back.
Does this sort of thing exist? Been searching a while.
I guess if I had to make one I'd fashion it after a ratcheting wire crimper: you squeeze up to a certain point, and it will hold there, but if you _really_ squeeze, the hold will release and the handles will back away when you let up. (Thinking aloud here I guess.)
