I am going to build up a disc wheelset for agressive xc use. I am thinking of using a 2 cross/3 cross lacing pattern with;
http://www.geocities.com/spokeanwheel/lacingsr.htm#23
Has anyone else tried this lacing pattern? How much will the difference in spoke tension be reduced? Are there any negatives to doing this other than the possibility of losing some torque transfer properties due to 2 cross instead of 3 cross pattern?
What are evreyone's thoughts on this?
Rear: 3 cross on the drive side, 2 cross on the non-drive side (disc brake side), and
Front: 3 cross on the disc brake side, 2 cross on the non-disc brake side.
The goal of this lacing pattern is to minimize the spoke tension difference between one side of the wheel compared to the other side due to the uneven offset of the hub flanges. This is explained better here:Front: 3 cross on the disc brake side, 2 cross on the non-disc brake side.
