1 - 4 of 4 Posts
whatever she says gueuze.
My stock steel spring is a 2.75x400 and I can get a 2.5x400 ti spring for a good price. It looks like the unweighted length should be fine but will this work? How would I notice the difference? Shock is a RC4. Thanks.
the best way is to measure it, but its very likely to work.
i use a 2.00 spring with a 2.5 shock, and it can't bind, because the gaps between the wounds are too large - i don't know who's the bozo who labeled it, but it is a progressive suspension spring (i use it on a fox shock).
using a caliper you measure the vertical distance between parallel wounds, and multiply it by the number of parallel wounds. if its less than the stroke, you're good to go.
wuss
Depends on the stroke of your shock.....
If your shock has a 2.75 stroke, a 2.5 spring will bottom out before your shock does....
The rating on the spring is just a promise that it will work in that set up, not that it won't work in any other set up.
I used a 2.25 spring on a 2.75 shock and there was no problem with binding, as the coils where so sparse. Mainly changed it because it had a tendency to tighten the preload collar while I was riding...
However I would not go for it unless you are really sure. Calculate how much space you have on the spring, make sure you have some extra and it should work fine.
1 - 4 of 4 Posts
