www.mtbtires.com, then go to specs, then kenda, then BG & NevTomFL said:I have a 2.5 Blue Groove to use as comparison and am wondering how the nevegal compares in width. Trying to see if it will fit on the rear.
-T
Thought of that, but unfortunately he doesn't list the 2.5 nevegal.jrm said:www.mtbtires.com, then go to specs, then kenda, then BG & Nev
They are so close, I'd say decide based on tread not width, since the casing is likely the same size. I have both which I swap out as needed on the front. The BG is great for hardpack to medium-loose, the Nev is great for loose conditions. Both work on wet rocks/roots.DM-SC said:Edited because I can't read Shiggy's site!
It appears that the BG is a smidge wider than the Nev.
