It is going to depend on the tire. Not all 2.3s are the same width. See the specs on my Tire Site for details.Wolverine said:Has anyone tried running anything larger than a 2.3 on a XLT 2.0?
If the 2.50s fit it should work fine. It will add a lot of weight and unless you have pinch flat problems the XC versions might work fine.Wolverine said:Like most others I was thinking of giving the Kenda NV & BG a try in the 2.5. However instead of the John Tomac series I was thinking of running the DH version (w/slime) to help avoid some desert punctures. Thoughts?
