Hey all,
I've done a quick search and have found a lot of questions about how wide a tire you can put on a rim, but my question is this..
How wide a rim can you use with a tire?
A little silly, I know, so I'll explain the sitcheyation..
I've got a 2019 Jamis Sequel that I've upped with all SLX stuff. It's a super fun and versatile ride (It's also my sole means of commute, ergo the choice of frame).
I'm not thrilled with the stock wtb st i23 wheelset. Just a note, it appears that these are cheaper oem type rims and NOT the Frequency range that one would be buying independently. The front bearings are already failing after only 6 months, I'm starting to hear some nasty spoke noises when trail riding, and to top it all off, I've failed at converting them to tubeless. I'm sure my noob-ness has a lot to do with it, but I have tried two different rim tapes and just can't get the job done. These rims have a very steep and deep spoke well and I can't seem to get anything to lay in there nicely. I did have some success with gorilla tape, but the stuff peeled off and failed very quickly. Just didn't hold up at all to the stans sealant, so I'm disregarding using non application specific tapes for now.
The other problem I'm having at this point is that I'm on a budget.
I've been looking at wheelsets and damn do they get expensive quick!!
I found locally a set of brand new take off RACEFACE ar35's with SLX hubs that match my bikes specs for a price I'm willing to pay. I REALLY like the SLX hubs given that they're cup and cone, centerlock, and match everything else on the bike.
The only problem is that the things have a 35mm inner rim width and my bike will fit a MAX tire size of 2.25.. Could I run my Vittoria MEZCAL 27.5x2.25 on a 35mm inner width rim? It's def overkill, right?
If I purchased this wheelset, I'd probably leave the mezcals mounted and only use them on the trail. My stock cheapie wheelset would still be used for commuting with some form of road plus tire.
So again, could I run (on the trail) 2.25" mezcals on a set of ar35's
or would that make the tire profile and or handling totally ridiculous??
I just don't want to spend money on something that I can't or won't like to use..
If you have any questions about the bike or my intended use, fire away.
Thanks for any and all input,
Travis
Travis
