1x10 questions
1377 Views 6 Replies 4 Participants Last post by  Grip
Ive been interested in going 1x9, and would like a little help on the topic.
From what research ive done, all i basically need to convert to a 1x9 setup would be the following:
Single chainring bolt set
Single chain ring ( 32T if i use my current middle ring )
A chain keeper
A stinger chain tensioner
I have the following:
Sram 11-34 9spd cassete
Sram X5 derailer, and shifter
Is that correct?
I can use my current 9spd chain, and rear cassete?
I feel like i missed something, or there is something i do not know.
1 - 7 of 7 Posts
I think you got it. Chain, cassette and derailleur can be used as is.
Alternative solutions would be:
- Tensioner/keeper combo (e.g. MRP Lopes SL)
- Chain tensioner and bashguard (e.g. e13 SS+ or MRP G2).
- Just a chain keeper and only buy a tensioner if you need one.
If you don't use a bashguard you'll need shorter chainring bolts. If you don't use a tensioner you can shorten your chain.
i dont have a bashguard and my chainring bolts work fine they dont get in the way at all, not saying it will be the same for you....i do suggest shortening the chain even with a tensioner and chain guide i had problems with mine before i shortened it
There's different setups you can do. My suggestion would be:
-N-Gear Jump Stop (cheap and works well)
-Any bashguard (Race Face, BBG, etc)
Other than that, you just remove your front shifter/derailleur/22t ring/44t ring, install the above parts, shorten chain as necessary and you should be good to go. You don't need a chain tensioner because you have a rear derailleur to tension the chain. You can also use a chain guide setup, like something from MRP, but that will be heavier and more expensive. If you want to go a little crazier, you could get a non-ramped chain ring as well. Another line of defense to keep your chain from dropping.
Lots of different options, but what I mentioned above will be the cheapest/easiest. You can get out of this whole thing for <$40.
So im good to go if all i add are:
Race face single 34t chainring
Paul chain keeper
Single ring bolts
I may or may not need to remove a few links?
I want a 100% reliable setup, i do not want to constantly be adjusting this setup, or dealing with dropped chains.
Paul chain keeper
Single ring bolts
Yes, that will work fine. Just use this:
http://www.paulcomp.com/ckclamp.html
Plus a non-ramped chain ring and the shorter bolts, or keep the same bolts and add a bash guard. You don't HAVE to remove chain links, but removing some will give you a little more chain tension. Do you know how to measure proper chain length? Put the chain around your biggest chain ring (or only chain ring, as the case may be) and largest cog (34t) and it should be 1 link longer than that (1 link = 2 "pieces" of chain). One more note, you don't need it, but you could also go with a short cage derailleur for quicker shifts. You won't need it to take up as much chain anymore.
1 - 7 of 7 Posts
