1 - 4 of 4 Posts
Converting to a 1x10 with a slx m675 double crankset and a raceface nw 30t chainring. So far I've put in 8.5mm bolts which leaves about 1.3mm of thread, which is about one a half to two threads exposed.
Could this cause problems and therefore should I rather source some 10mm bolts?
Discussion Starter · #3 ·
Thanks for the reply.
The 2.5mm shim on the nw ring should put the chainline on shimano's stated 48.8mm for the double crank. Assuming I'm trying to achieve a chainline of 45mm for a 142 hub, it makes sense to put the bb spacer on the non-drive side? The bike is a rocky mountain slayer with a 73mm bb shell.
1 - 4 of 4 Posts
