1 - 8 of 8 Posts
Hello - I finally got my 1UP and was planning to pickup a D lock to use as a safety connector, (wanted something a little more secure than the Velcro strap for piece of mind) but after looking around on Amazon I found a short cable and a stainless steel carabiner that seems to work quite well...thought I'd share this setup, since it was all together only about $15. I purchased the 1UP lock for the hitch bolt so I didn't need another lock on the cable.
  • ONGUARD Akita Loop Cable Lock (Short 53cm x 5mm 1.72' x 0.20'')
  • PROND Locking Carabiner, Heavy Duty Carabiner, 316 Stainless Steel Screw Lock Carabiner Hooks
Line Bicycle wheel rim Bicycle accessory Steel Metal
Automotive exterior Windshield Automotive window part Gas Shadow
Was this a recent order of the 1up? In another 1up thread, someone pointed out (and the website seems to confirm) that they added a slot in the square tubing so that a lock could be inserted through the hitch pin holes. Doesn't look like yours has that. Your solution appears to work well though.
Discussion Starter · #3 ·
@aski - This rack was purchased about 4 weeks ago. I didn’t hear that there was a change to the square tube, I called 1UP before placing the order and asked if there were any upcoming changes or features coming out and the rep said no. I’ll take a look at their website.
All fat, all the time.
What benefit does the velco/cable provide?
From looking at the pics I can't tell what the intended purpose.
Just a safety precaution to ensure the rack doesn't slide out in case the tightening ball gets loose (which mine never has).
These racks don't have a pin that slides through like normal.
Ahh okay. Didn't realize they weren't held in with a hitch pin.
One Up is on my list for my next truck -good to know these things.
1 - 8 of 8 Posts
