Should work fine for you, but if your measurements are correct (and I converted them right) then you'll have some post showing (about 6") and prob use a 120-140mm stem - not sure how you measure arm length, but my total arm span is 6'3". I'm 6'2.25" w/ a 35.25" inseam and have the same size KM and run a setback post with about showing and use a 140mm stem. I originally got the 140mm stem because I had bought a hug sweep bar to try and it just brough everything back too much, but I've since gone back to a normal bar, but kept the 140mm stem - I prob could go for a 130mm.
