I've read that this combo should work fine...true? I have watched the videos/searched/etc...totally get the basics, and I plan on going ghetto (split tube) and mixing up my own sauce. Just a couple questions:
1. Can I effectively use a 26" tube on a 29er rim, or do I need to get 24" tubes?
2. After you have mounted a tire and cut the excess tube away, is it possible to unmount that tire and get it re-seated on the same tube, or do you need to use a new split tube every time you unmount a tire?
3. When and how can you use Gorilla Tape? Is it possible to use this instead of a tube in my application, or does it have to be a tubless specific rim or tire or something? I know nothing about using it, but I have some in the garage and I bet it's lighter than a tube.
Thanks in advance.
Thanks in advance.
