1FG and a Lefty?
1416 Views 14 Replies 4 Participants Last post by  mtnbikerx
I have a 1fg 2005 and put on a lefty(100mm air) and the bike seems very sluggish? I have checked the hubs, eccentric, bottom bracket, changed gears and tires. Does the lefrt change the geomerty to cause this? Any help!!!!
1 - 15 of 15 Posts
Wierd, the 80mm headshock, and a 100mm lefty have the same axle to crown, plus or minus 2 mm, it should be fine. Did you have a 80mm headshock on there before before?
the bike was built up but I just rode a new 2005 with the headshock and it was much better. Thought the lefty woud be cool.
Something else is going on. Headset bearings ok? Is it dragging when you turn the handlebars? The Lefty will be cool, just have to get to the bottom of this!
I have switched a lefty 110mm and an 80mm Headshok back and forth on a scaple and have not noticed it, but I know atleast two other people who say they think the scaple feels slower with the Lefty. This has been tried with a number of Headshoks and Lefty's so bearings, hubs, wheels, etc.. should be out of the equation. In my mind that only leaves gerometry changes.
Had a thought, that the trail, and or rake, might be different, checked with Cannondale, they are the same, which brought on a great thought from them, we checked the geometry between Scalpel models, equipped with one or the other, the numbers are identical. Hmmm, the plot thickens=:)
Thank you for your help. I will do a side by side check with the other new 1fg(headshock) that I rode and mine(with the lefty) and get some measurements...I will keep you posted.
A leetle OT but
I'm wondering if the Fatty headshock installed in a 1FG takes a standard headset? I've had a Manitou on the 1FG and I'm thinking about installing a Fatty. Just a std Chris King?
Hey there, no, the Headshock system, be it Lefty or Headshock, is it's own headset size and style. It should be readily orderable, if not available right then, from your LBS. Sorry, the day King makes a Lefty headset, I will be the first in line!=:)
Thanks Mendon, I'm not really a bike dummy (5 Spot, RFX, VPX, 6.6, 1FG) but I know nothing about the C'dale line. My 1FG seems to have a normal ID headtube albeit long on my large frame. Do all the headtubes on the 1FG's have the same ID? Some of the C'dale frames I see pictured have an obviously fatter head tube.
Scratching head, .... as far as I know, all the 1FG's ever made have had the same, headshock compatible headtube, got a pic?
Shown after I pulled the Firefly and CK headset out of her.
Now I'm confused. That certainly appears to be a 1 1/8" headtube, pics have a way of looking funny though. Was a King pressed directly into the frame, or was there some sort of reducer cup in there first? I'll dig a bit, I thought they were all Headshock, I've been wrong before though!
Nope 2004 there was a 1FG with a regular headtube and a rigid fork.
http://www.cannondale.com/bikes/04/cusa/model-4MRSS.html
So you will not be able to put a Headshok or a Lefty on this bike, sorry.
OK, on the civilian 1FG. That eliminates a disconnect I had on the fork thing. I thought I might PU a headshock and "return the frame to it's natural element".
I'm thinkin' about selling this puppy if anyone is interested. :eek: I'm just not a SS guy.
1 - 15 of 15 Posts
