Who even knows?
  • Not Me!
    Votes: 0 0.0%
1 - 6 of 6 Posts
I have a 1994 Stumpy that has a worn out front shock fork. Does anyone know what would happen to my geometry if I replaced this shock with a new 80mm shock? Will it totally screw it up?:rolleyes:
VRC Illuminati
If your Stumpy came stock with suspension, the frame should be adjusted for suspension...albeit around 63mm's worth.
I doubt you'll notice any ill effects of running an 80mm fork.
I've got a '94 Stumpjumper frame that I've run with everything from a non-suspension corrected rigid fork (Accu-Trax) to a 4" Z.1 (63mm Judy in between). It worked fine in all modes. I don't think the extra inch or so over the 2" forks of the day will kill the handling.
1 - 6 of 6 Posts
