meiwah98 said:
I have a 1992 Rascal, came with a Manitou fork - the fork is comprised of 3 small rubber balls inside each fork (my how technology has changed). I want to upgrade to a modern day fork, but someone told me the fork is not "threaded." Not being mechanically inclined, he said it would be hard to find a modern fork that will fit the Klein Rascal (HT).
Can someone please clarify and make recommendations?
Thanks.
:thumbsup:
Find and go back to the original rigid fork. That's what I'd do.
You can find a suitable replacement, but most likely you'll have to get a threadless headset and stem to go with the threadless fork...
You'll need a 1" fork which are highly saught after if it's a decent fork SID's, Judy's, Zocchi's...they're out there, but you need to keep a sharp eye out for them.
You could try and find replacement internals for the fork you have. There are some coil conversion kits out there for those forks, but they're also hard to find.
Also want to keep in mind throwing off the geometry of the bike some with longer travel forks.
