1 - 5 of 5 Posts
I wanted to put some nicer rims on it, but found out that my original Mt. bike was a 6 speed.... 130mm drop width, right?
Anyway, at this point it looks like I need a 18T bmx freewheel and a 36T chainring for the Sugino Crank. I can run a retired 8spd chain, right ?
Any recommendations on the freewheel or the chainring setup ? or anything else in general that I should be aware of ?
The stem is a goofy looking quill that holds the cable for the canti brakes.... recommendations??? should I use a quill adapter ??
Thanks,
JK
ps.... the dropouts are semi horizontal, but I did do the calcs to determine that a 36 x 18 would give me the best fit without a tensioner. Assuming the gear inch feels right....
I have an '80's Stimpjumper, 1in. threaded headtude, also have the canti quill. You can see a pic of it in the Photo gallery in the SS section. I am using XT v-brakes, 8 speed chain, no tensioner. I just got a back wheel from a friend with an 18t freewheel that I haven't mounted yet. I'll let you know how the chain line ends up. Post some pictures.
kef
no tensioner?
Kef,
what gear ratio have you found to set this up with no tensioner (or is there some other invisisble trick?)
am turning my specialized s works back into a singlespeed.....
matt
1 - 5 of 5 Posts
