So, I know that a bunch of you (MellowCat, Padre) have broken these... I've got a set on my Soulcraft Plowboy that I haven't broken, but I have managed to slightly round out the square taper hole on the left arm. At least that's the theory because no manner of proper torquing and blue loctite will keep the thing from staying tight after a few rides. Any chance I could've rounded the Ti spindle on my RF BB...?
Anyway, if I remember correctly, I think that most of the threads I saw about the RF turbine crank failures showed broken drive side arms. So, I'm thinking that some of you may have a perfectly good, 180mm, left side arm sitting in the bottom of a parts box. If so, any chance you'd want to part with it?
Thanks in advance!
BTW, if I can't make this work, I may have a nice 180mm, black drive side for someone
Thanks in advance!
