siv said:
Can someone explain to me how 5mm makes a difference? Im the tallest 6 footer in the world, long arms with a 34-35 inseam and tired of feeling like Im going over the bars without lowering the seat.
Don't know that the 5mm drop in seatheight would help with that.
For Going over the Bars:
-Raise your bars(find some high rise bars, max out the spacers and use a high rise stem
-Get a Gravity Dropper or other post with handlebar controlled dropping
-Get a shorter stem so you can get your weight further back
-Check that your fork is set-up properly: not too much rebound damping,not too much sag and maybe some compression damping if your fork has a platform system, to combat 'diving' of the fork.
-Check that your rear suspension is set up properly (if you have it), enouhg rebound, not too much platform compared to the fork.
Or just go back to the shop where you got it, tell them what's up and if they don't go through this stuff with you, find a new shop.
