I'd wager at your weight you'd be happier with at least a 185 up front, and if you're riding any seriously long descents, you could justify a 203.
Depending on your braking technique, a 160 in the rear ought to remain OK, but if you use it a lot to check your speed, a 185 would handle the heat better.
