1 - 2 of 2 Posts
· person
Doing a little planning for my next build. Can an 04 Coiler handle a 160mm Fork? The fork would definitely have adjustable travel. If it is possible, I've been looking at either the Talas RC2 or the Magura Wotan, both due to there very low A2C heights (545mm and 540mm respectively I'm believe.) Other question is how would a fork like that effect the geometry. With the stock fork the head angle is listed at 68 degrees, would that change it to something like 66 degrees?
· Meh.
Bike can take long travel single crowns and DCs just fine. If it still had a warranty, neither would void it.
Obviously the bike is going to be a bit more slack and a slightly higher TT and BB. The Drop-Off it came with had a relatively high A2C height. IIRC the 130mm fork was actually taller than my Pike at full extension.
1 - 2 of 2 Posts
