Can someone confirm this will work?
www.jensonusa.com
Shimano F180P/P2 Disc Brake Adaptor | Jenson USA
Thanks for that. I am assuming that this really isn't brand specific, so that same spacer specs for Sram given that the mount points are derived at the frame or the fork?Here's a breakdown of what adapter for Shimano you need where, frame or fork, post mount or IS.
As mentioned, mostly it's mount type and not brand - except if you're going to 200 (SRAM) or 203 (Shimano) or your brakes are from Hayes (caliper shape doesn't work with Shimano adapters of any size or SRAM 200mm adapters).Thanks for that. I am assuming that this really isn't brand specific, so that same spacer specs for Sram given that the mount points are derived at the frame or the fork?
It's an expensive way of doing it, a Shimano adapter will do exactly the same thing for a lot less money.Anything wrong with using something like this?
