Hi guys I'm gonna build a 5010 v4. My local store has a fox performance 36 160mm coming from a mega tower. He told me that he can modify the fork to make it a 140mm excursion. After that mod will the fork working as good as a 140mm native?
This^Yes. Only difference between a 160mm and 140mm is the air shaft. Unless it's a pre-2017 model then they are exactly the same you adjust travel by changing the length of the transfer rod.
