1 - 12 of 12 Posts
I just ordered a Redline Monocog Flight 29. I wasn't happy with the BB5's on the bike I rode at the shop. They required too much lever force to lock them up. I want to replace them with the BB7's and am wondering if I should go to 185 or 203 mm from the 160's.
Also, is anyone aware of a different set of cables that would help with brake performance?
No, that's not phonetic
You could run a 185 in front and leave the rear at 160. Most of the braking power comes from the front wheel. Any die-drawn stainless cable and a decent quality, lined, generic housing (like QBP's house brand) that has been cut correctly (with a dremel- not with the ends crushed) should give you very smooth, compression free action.
...idios...
It's not usual for a brake on a shop bike to be bedded in fully. The BB7 and BB5 work the same way, although the BB7 has a slightly different level of adjustment.
Don't write off any system until you've tried a version which is fully set up and the pads/rotors have bedded in.
Peace,
Steve
Super Moderator
Steve makes a good point... it is very likely the brakes at the shop were not bedded in.... the only thing I would see as disadvantage of also running a 180/185 rotor in the rear is that if you are a lightweight, the brake could lock up very easily as your weight shifts forward.
As Tscheezy stated, you can get a bigger front rotor and stay with 160 in the rear... I personally run 203/180 in my FS and 185/160 on my ss and feel good with both setups, but I weight about 210 lbs.
Premium Member
Peace,
Steve
Agreed! Until they have bedded in a disc brake can fell and work poorly.
With the last bike I put new BB7s on I could not stop the bike while pedaling on the flat at first. By the end of the first 12 mile ride they were up to the one-finger performance I love.
Discussion Starter · #9 ·
Thanks for the info. Didn't think about the brakes not being bedded in. I'll give the stock ones a shot for a month or so and see how they work. If I'm not satisfied, I'll go to the 185's. BTW: I'm not a "light weight" 200 lbs.
Freshly Fujified
Good question
euroford said:
if your going to upgrade brakes why would you not go hydro?
Potentially several reasons to include cost and the fact that a well set up Avid mechanical disc brake configuration performs as well or better than some hydros. Preferences play a part also.
Bob
Actually I was in the same boat of having OEM discs, but couldn't find replacement pads and would have to buy a complete new set of brakes - calipers, lines levers - and was going to go BB7's, but when I added up the cost of getting them all it was so close to a set of HOPE Mono Mini's that I went with them instead. The good thing about going mech disc is that if you already have levers for V-Brakes you just need to buy the calipers.
Bob
1 - 12 of 12 Posts
