Hi,
I need a triple crankset (or triple crank arms with no rings on) with the following specifications:
JIS square taper;
160-165 mm crank length;
104/64 BCD;
45mm chain line (please, specify which bottom bracket spindle length is required to get that value, if possible);
Q-factor around 160mm
Anything on the market with such features?
Thank you for your help,
crankpaul
JIS square taper;
104/64 BCD;
crankpaul
