1 - 4 of 4 Posts
Ok, heres my deal, I picked up a 15mm through axle Fox F29 for my Fisher Paragon, and well I cant find any hub adapters that fit. My local shop said they cant find anything either, so I drew up what I need and gave it to a machinest... Anyone see any potential issues with what im trying to accomplish here?
I would much rather keep my existing wheel and hub until I can gather up the funds to buy somthing new, its just not in the picture at the currrent time.
Heres my junk (bike).
Discussion Starter · #3 ·
mtnbiker72 said:
I know the bearings are 17mm inner diameter on the Race hubs, did you just need to machine the end caps or did the axle need machining as well?
full replacement of everything inside of the hub. wheel adapters are being machined to ride the bearing inside of the hub, axle through machined hub adapters.
Banned
Wow, around here the machine work would cost more than a new front wheel. Heres hopeing you got a deal. Sounds like it will work as long as the overall length is correct.
1 - 4 of 4 Posts
