Wanted to hear some feedback from the XC racers and riders that are using thru axle designed forks for XC racing.
I had a sid that i beat to a pulp after two years of racing and loved the hell out of it.
I replaced it with a Reba XX fork and love that fork but want to stiffen the front end up even more so was looking into replacing the reba with a 20mm thru axle design.
I would have went back to a sid but their thru axle XX version is only offered in 120mm travel.
My questions for those that are using this on XC bikes are what are your impressions over the "advantages" that the thru axle offered.
Do you feel this is too much fork for XC racing with the 20mm version?
I race hard and torque the hell out of the front end on sprints enough that I get the rotor rub and not sure if this is related skewers coming loose as well under hard riding( swapped hubs, forks and skewers and still can get em loose).
A 20mm thru axle means for me another CK hub swap up front and a new fork.
I looked into Fox forks that have a 15mm thru axle which means I could use a CK converter fork, but I love the XX hydraulic lockout and the 80-100-120mm travel options.
so ladies and gents tell me what you think after you went to 15 or 20mm thru axle for XC racing and riding.
