1 - 18 of 18 Posts
aka bOb
So if 150mm is going to be the new front hub standard and I have a 135mm thu axle which is technically a 142mm could spacers be made to make the 142mm work? Or is the 150mm actually going to be 157mm? I guess we can't talk about the new f**k but could this be a way one could switch between a summer and winter f**k using the same wheel?
Brake rotor would need some sort of spacer also, not sure if that is possible. Not that I'm even considering a suspension fork, but I was pondering the same question and whether my Hadley 135 hub could be used. So I guess I would have to go Lefty, Fork of Many Names or Flame, but not Fork Whose Name We Shall Not Speak.
If it is a front disc spaced front hub, the rotor would need to move outward 7.5 mm. This type of thing is routinely done to move a rear spaced hub's rotor position out 5mm for a front spaced fork. I'm not sure if the extra 2.5mm would push it over the edge and cause failure. If not, longer bolts and washers would do the trick.
A rear-spaced front hub would need to be moved outward 12.5mm. That's scary far in my opinion.
Harder though might be the axle spacers. They would need to have precise dimensions.
Its actually pretty straight forward. You just need a rear spaced 142mm hub with 135mm reducer and a 12mm TA w/ 15mm conversion kit. But you may also want to consider the 160mm to 203mm adapter with a 2.5mm offeset and rear disk spacing. One should also investigate the use of a 150mm front hub with a 142mm axle and 135mm brake adapter w/ funbolts. This all could be avoided if you just utilize a BFH, some Gorilla tape, wish in one hand, and piss in the other.
I saw a guy using the same methods mentioned about, and it was a riot. The piss really did make a mess of things thought.
aka bOb
Discussion Starter · #8 ·
Second best Jon post ever, can't mention the first:eek:
Banned
150mm is going to be the new hub standard? And all this time I was contemplating the consequences of 190mm becoming the new rear standard. Goes show that I should stop worrying about obsolescence and just ride my bike!
1 - 18 of 18 Posts
