how tall is she?
It's odd though that Kona would sell a bike like this: In 2003, long before the curvy tubes, the Dawgs had straight top tubes for every size. When this was the case, the 15" had a 30", the 17" was listed at 31", so the 15" in 2003 was 1.5" lower than the current 15". If the 15" has no curvy tube for '08, then there's still another 1.5" to explain. Is this all due to the height of the unsprung, longer travel suspension? Seems like an awfully awkward package. Who would/could ride such a tall, short frame appropriately?KAHAIKAPU said:Hi I Beleive The 15 In Frame Upper Tube Is Straight And Not Bent Like The Larger Frames.
But its not irrelevant to proper safety. Nothing like coming off the saddle to smash the goodies.:yikes:tomsmoto said:standover is irrelevant to proper fit.
If she can't stand over it, then she won't stand over it... and she won't ride it. Oh well :bluefrown:frdfandc said:But its not irrelevant to proper safety. Nothing like coming off the saddle to smash the goodies.:yikes:
Yeah, it looks like that shock is wedged in there as tight as possible; no room for a lower toptube with this design. I guess with the 17" being a bit longer, they were able to run it lower? Yep, it's odd. Sure looks good though.irvintat said:Here you go...these will give you an idea. I'm 5'6 & the standover barely fits me. So, probably too tall for her. I thought the sizing was weird myself. Shorter people are basically just SOL.
id be pretty surprised if you could find a bike with the proper top tube length, with a standover so high its actually a problem.irvintat said:It's not irrelevant if you can't even get your feet on the ground.
