1 - 3 of 3 Posts
Hi all,
I don't know much about all the newer stuff on the market. I want to get gears on my Monocog 29er, knees are taking a beating.
Shimano FH-M775 XT Rear Disc Hub
http://www.universalcycles.com/wheelkit_new.php?Action=showDetails&ProductID=19064
The above hub has the 14mm axle. Will this fit in the rear drop out of the Monocog?
I'm thinking of having this built with the Stans ZTR flow in the 36 hole variety.
Will be going disc brakes also.
Will the hub fit the bike??
thanks, MikeB
The Punk Hucker
The axle is 14mm but it's ends are normal 10mm QR so it will fit.
This hub is centerlock so you might need an adapter if you have 6-bolt rotors.
1 - 3 of 3 Posts
