1 - 6 of 6 Posts
Old man on a bike
135 is the standard spacing for mountain bike rear hubs (130 for road hubs these days). Your Heckler is 135. 150 is for a thru-axle setup used mainly on heavy duty freeride/downhill bikes.
He be a moose too.
What does the extra 15 mm. get you?
Old man on a bike
Here's Santa Cruz's words:
150mm wheel spacing with 12mm through axle is becoming the new standard for downhill and freeride bikes. The advantages are: 1) Waaaaay stronger wheels because of the dishless (or almost dishless, depending on the model) hubs. Wider hub flange spacing + no dish = stronger wheel. 2) To match the wide wheel, a wide bottom bracket must be used to provide proper chainline. This keeps your chain further away from the rear tire- allowing for a granny ring with a 2.7-3.0" tire and no rubbing.
1 - 6 of 6 Posts
