I will start off by saying, yes I know that Fox says I need a new damper cartridge.
The fork is a 120mm 2017 34 Performance with the GRIP damper. On the work stand, I can pull the damper out about 30mm more. I am wondering if, despite Fox's recommendation that I need a new damper, is there an actual problem with changing to a 130mm air shaft? Will the damper be damaged, or will it not perform correctly? Or is it like frame tire clearance, where frames can almost always safely fit wider tires than the manufacturer recommends?
